Processors
14553 Discussions
i7-6700k weird temps?
APllu
Hey guys
Have a i7-6700k
H100i GTX AIO cooler
ASUS Z170 Pro Gaming Motherboard
16gb Corsair Ram
Gigabyte GTX G1 980ti
My Temps at idle are about 23-29c
But if i do anything, i mean even open up a browser the temp will spike to about 70-80c for a sec and then instantly cool back down to idle temps.
If i run a stress test the temps will max out at 81c and then instantly as i stop the stress test the temps go back to idle.
This is playing havoc with my fans as they will ramp up everytime i click something with the mouse
I have checked and replied thermal compound. Are the temps reading wrong
Any help would be great thanks
Anthony
Amy_C_Intel
Hello, AnthonyP:
Could you please run the https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool Download Intel® Processor Diagnostic Tool and attach the report once done?
CYild
APllu
Hi amy, since installing this program my temps are now only peaking at 65, down from 83, was there any micro code update with this Diag tool?
Results bellow. the cpu is still spiking when i do anything just not as bad
--- IPDT64 - Revision: 3.0.0.23.W.MP
--- IPDT64 - Start Time: 2/21/2016 2:31:18 AM
Processor 1
Intel(R) spbc Module Test
Module Version: 1.0.7.64b.W
Start Time: Sun Feb 21 02:31:18 2016
Test Result - PASS
..!!..Processor under test is verified as 'PRODUCTION'..!!..
Processor Manufacturer: GenuineIntel
Processor Brand String: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
End Time: Sun Feb 21 02:31:18 2016
Total Time: seconds: 0
Genuine Intel CPU Test
Module Version: 1.0.12.64b.W
Start Time: Sun Feb 21 02:31:19 2016
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
End Time: Sun Feb 21 02:31:19 2016
Temperature Test
Test Result - PASS
Expected: Greater than 1 degrees below max
Received: 50 degrees below max
CPU Brand String Test
Test Result - PASS
Expected String Parts: As Defined in BrandString_LocalConfig.xml
Detected: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
CPU Frequency Test
Module Version: 1.0.14.64b.W
Test Result - PASS
Processor Name: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
Expected CPU Frequency: 4.00
Detected CPU Frequency: 3.98317
Expected Base Clock: 100
Detected Base Clock: 102.133
QPI link rate Test - Not supported.
Skipping QPI link rate Test.
End Time: Sun Feb 21 02:31:23 2016
Total Time: seconds: 4
Floating Point Test
Module Version: 1.0.10.64b.W
Start Time: Sun Feb 21 02:31:23 2016
Test Result - PASS
Million Floating Points per Second, MFLOPS: 662.4
Error: 0
--- Floating Point Test Passed!!!---
End Time: Sun Feb 21 02:31:25 2016
Total Time: seconds: 2
Prime Number Generation Test
Start Time: Sun Feb 21 02:31:25 2016
Test Result - PASS
Operation Per Second: 7.31037e+006
Error: 0
--- Prime Number Generation Test Passed!!!---
End Time: Sun Feb 21 02:31:27 2016
Cache Test
Start Time: Sun Feb 21 02:31:27 2016
Test Result - PASS
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 32
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 256
- Detected L3 Cache Size --> 8192
Cache Size Test Passed!!!
MMXSSE Test
Test Result - PASS
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - MMX Supported --> Yes
SSE - SSE Supported --> Yes
SSE2 - SSE2 Supported --> Yes
SSE3 - SSE3 Supported --> Yes
SSSE3 - SSSE3 Supported --> Yes
SSE4.1 - SSE4.1 Supported --> Yes
SSE4.2 - SSE4.2 Supported --> Yes
--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
AVX Test
Module Version: 1.0.11.64b.W
Test Result - PASS
--- Determining AVX AES PCLMULQDQ capabilities ---
--- AVX/AES/PCLMULQDQ ---
AVX - Advanced Vector Extensions Supported --> Yes
AVX OS Support - AVX Operating System Supported --> Yes
AES - Advanced Encryption Standard Supported --> Yes
PCLMULQDQ - Polys Carry-Less Multiply Supported --> Yes
--- AVX AES PCLMULQDQ capabilities check complete ---
AVX Compare Test Result --- PASS
AES Test Result --- PASS
PCLMULQDQ Test Result --- PASS
IMC Test
Test Result - PASS
--- Reading Memory Size ---
Detected Memory Size is --> 16.00GB
--- Subtest - Memory Size Test Passed!!! ---
--- Integrated Memory Controller Stress Test ---
Memory to be allocated = 1048576 byte
Memory Allocated.
Test 1 Ones and Zeros Moving Inversions write operations - Passed
Test 1 Ones and Zeros Moving Inversions verification operations - Passed
Test 2 32Bits Sliding Ones write operations - Passed
Test 2 32Bits Sliding Ones verification operations - Passed
Test 3 32Bits Sliding Zero write operations - Passed
Test 3 32Bits Sliding Zero verification operations - Passed
Memory Deallocated.
--- Subtest - Memory Stress Test Passed!!! ---
Integrated Memory Controller Stress Test Passed!!!
End Time: Sun Feb 21 02:31:28 2016
Total Time: seconds: 1
PCH Test
Module Version: 1.0.9.64b.W
Start Time: Sun Feb 21 02:31:28 2016
Test Resul...
Amy_C_Intel
Thank you for the report.
According to it, everything seems fine with your processor, maybe you could try setting the default settings in the BIOS and see what happens.
APllu
Amy
I have attached an image that shows what i mean, the temp will spike 10-20c on the slightest of cpu usage. i have used a temp sensor and sat it on the side of the CPU heat spreader and i got a constant 27c on idle and 44c on load. but the readings from the CPU sensor dont reflect this.
This image is just me doing basic web browsing no video or gaming and the temp will not stabilize
Amy_C_Intel
This behavior is normal. As long as the case temperature stays under 64°C it is OK, see here for the TCASE specification http://ark.intel.com/products/88195/Intel-Core-i7-6700K-Processor-8M-Cache-up-to-4_20-GHz Intel® Core™ i7-6700K Processor (8M Cache, up to 4.20 GHz) Specifications.
