Processors
14633 Discussions
i7-7700k thermal throttling below 60°C
KKova2
Here is my problem with my i7-7700k. Pictures attached below.
It keeps doing thermal throttling when it is heavily used. Pictures below shows underclocked/undervolted, but the situation is worse on stock settings.
PSU is EVGA Supernova G3 550, it can't be a problem.
Any suggestions ?
Hello, Kiskoko.
Thank you very much for contacting the Intel® Communities Team.I will be more than glad to assist you further in respect of the Thermal Throttling inquiry you have.
I would like to mention that these results are expected when performing a stress test to the processor even if the settings were modified to make the microprocessor to a lower frequency. Additionally, you can verify that your heatsink is installed correctly and that you have a good airflow in your case.
Furthermore, please run the https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool Intel® Processor Diagnostic Tool just to make sure that your unit is not having any problem. Please share with us the results.
Antony S.
n_scott_pearson
Just an observation: I also wonder if there is some ACPI code activated that is implementing passive cooling.
KKova2
Well, reapplied the heatsink. Thermal throttling is gone @4.0GHz 1.1volt. But still there on stock settings.
You say it's normal if CPU is under heavy load...
I say, I'm not happy with this. I paid a lot for this CPU and can't use it on stock settings.
I have a properly installed heatsink for sure, and still have throttling issues.
Ran the https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool Intel® Processor Diagnostic Tool , it passed.
n_scott_pearson
No, I didn't say it was normal; it is *very* abnormal. I was saying that ACPI-based passive cooling (i.e. throttling) may be enabled and, if it is, it is incorrectly configured (hell, grossly misconfigured). Check your BIOS configuration.
KKova2
I was answering to Intel's message. not yours.
By the way, found out what is the problem.
My MOBO VRM was too hot, and it caused PROCHOT: YES.
Thats why CPU was throttling.
have to buy new MOBO.
