The intel extreme tuning utility dosent open up, like it just stays in the loading screen for a few sec and then close automatically, i dont wanna overclock anything, i want to like keep a check on the tempratures and fix the power limit throttling issue
specs-
i7-2600
4gb ddr3@1333Mhz
Windows 10-1909
Intel HD 2000
300W PSU
Intel DH61WW motherboard
Hello Ninja,
Your Intel® Core™ i7-2600 Processor is not supported to use the Intel® Extreme Tuning Utility (Intel® XTU), you can check that here, under "This download is valid for the product(s) listed below":
https://downloadcenter.intel.com/download/29183/Intel-Extreme-Tuning-Utility-Intel-XTU-
You can also check with your system manufacturer (OEM) for other tunning or monitoring tool compatible with your system.
Sebastian M
Hello Ninja,
Sebastian M
Can I expect it to be added in the future?
Thanks for the fast response
Hello Ninja,
Thank you for your reply.
The Intel® Core™ i7-2600 Processor is a discontinued processor, and also the Intel® XTU is made only for unlocked CPUs (K and X SKUs). So, unfortunately, it will probably not be added. You might want to check other third-party tools for monitoring since your Intel® Desktop Board DH61WW is also a discontinued product.
Since our previous post was marked as a solution, we will proceed to close this inquiry. If you have any other questions; please submit a new thread since this one will no longer be monitored.
Sebastian M
