I use Kaspersky Internet Security and they have a Safe Money program that disables any kind of screen capture during online banking. I cannot enable virtualization which is what I need because I can't get into BIOS to look for it. I have a Win 10 desktop Intel Core i5 33350p cpu @310 GHz
I would like to have your current processor model number. I was not able to find an Intel® Core i5-33350p.
Please bear in mind that the only way to enable/disable virtualization would through the computer BIOS.
Try running the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel® System Support Utility and attach the results.
Allan.
thanks Allan.. I saved the file from the system utility but don't see a way to attach it here so I went to the support ticket and submitted it there
Thank you for updating this thread.
In order to attach files, make sure you select the "Advanced Editor" option in the top right of your reply window. You will then be presented with an attach file dialogue at the bottom of the reply.
Allan.
Here is the attached file.. thanks for pointing out how to do it.
Thank you for attaching the report.
In regard to the processor specifications, the Intel® Core™ i5-3350P handles the following VT features. Intel® Virtualization Technology (VT-x) ‡YesIntel® Virtualization Technology for Directed I/O (VT-d) ‡ http://ark.intel.com/search/advanced?VTD=true&MarketSegment=DT YesIntel® VT-x with Extended Page Tables (EPT) ‡ http://ark.intel.com/search/advanced?ExtendedPageTables=true&MarketSegment=DT Yes
I understand this issue might be supported by Kaspersky since their software disables Intel® VT.
Please check this link for further information: https://support.kaspersky.com/12163 https://support.kaspersky.com/12163
https://my.kaspersky.com/?_ga=1.26782653.1007289394.1483014207 Kaspersky Support
Allan.
![](/skins/images/D2683F18326913BBA0436CB7114DD569/responsive_peak/images/icon_anonymous_message.png)
Topic Options
