Processors
16207 Discussions
windows 10 老是突然无法调节屏幕亮度
何清歌
更新过windows10更新后有的问题,屏幕会突然闪一下,然后亮度就变成最大,需要卸载核显驱动重启电脑,才能调节这是什么问题????
而且这个问题随时突然发生!
Victor_G_Intel
Hello 何清歌,
To better assist you, can you please provide the following reports and information:
Intel® System Support Utility (Intel® SSU)
Instructions
  • Open the application and click on "Scan" to see the system and device information
  • By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
DXDIAG
Instructions
  • Go to Start > Run or Windows Key + R.
  • On the Run prompt, type "dxdiag" then click OK.
  • On the DirectX Diagnostic Tool window, click on Save All Information.
  • Browse to a folder, type in a filename then click Save.
Intel® Graphics report
Instructions link:
https://www.intel.com/content/www/us/en/support/articles/000005848/graphics.html
Notes:
  • With the graphics report, you don’t have to send both reports from both tools, just the one that you currently use (If applicable).
  • You can use the option under the reply window to attach the reports and any other files to the thread (Drag and drop here or browse files to attach).
  • Our support is only provided in English.
  • We may not be able to translate the screenshots attached to the thread.
  • To better assist you, we use a translation tool embedded in this Intel Community.
  1. Besides the Windows update did you complete any other changes as hardware or software related?
  2. Is this a new computer?
  3. Before the issue started were you able to have a normal/expected performance?
  4. Is this issue happening with a built-in display in case your computer is a laptop or is it happening with an external display in case you are using a desktop?
I look forward to hearing from you
Victor G.
Intel Technical Support Technician
Victor_G_Intel
Hello 何清歌,
Please let me know if you need further assistance.
Victor G.
DeividA_Intel
Hello 何清歌,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
