21615 Discussions
2.5VCCIO and 1.8V logic
I am designing a board using the EP3C40F324C6N device.
The A/D converter that I am using has an LVDS data bus and 1.8V control logic. If I have VCCIO connected to 2.5V (which is required for LVDS), can the same IO bank accept 1.8V logic?
The app notes that I have found all deal with the incoming logic voltage being higher than VCCIO not lower than VCCIO.
Bob
Look at page 1-11 of volume 2 chapter 1 of the CyIII device handbook (http://www.altera.com/literature/hb/cyc3/cyc3_ciii52001.pdf) It looks like the 2.5 I/O bank will work of with 1.8V inputs. However, be aware that this I/O bank will output 2.5V, which may or may not play well with the external device (A/D?).
--- Quote Start ---
--- Quote End ---
It could work but you have to keep a few things in mind:
- Like Ironmoose wrote: be aware that the output will be 2.5V
- The minimum Vih of a 2.5V bank is 1.7V
- The Voh of your external device will be close to 1.8V in practice, but your datasheet will probably specify 0.7*Vcc or so. So not enough
- A pull-up resistor to 2.5V on the input signals could give these a last step.
- The noise margin (difference between Voh and Vih) will be very small
- The use of a schmitt trigger input will improve the noise insensitivity
Good luck, Ton
PS Maybe the bus hold functionality could be use, but I don't have any experience with it
Thanks for the advice!
