hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
Programmable Devices
21325 Discussions
AGFB014R24B2E2EV : Evaluation board not booting with eMMC memory
MK_086
Dear Experts,
We received the new AGFB014R24B2E2EV Eval board when we switched on the board the HPS Linux running was noticed on UART when Out of box experience daughter card was plugged in. No prints are seen when the NAND daughter card is plugged in and the eMMC flash boot option is chosen.
Please help.
EBERLAZARE_I_Intel
Ok, so let me check that again, just to be clear, you would want something like below correct?, but on your custom build RFS, where your custom/helloW C will be stored as well:
https://www.rocketboards.org/foswiki/Documentation/AgilexSoCGSRD#Display_Hello_World_Message
I will check with out internal team on that if that is correct.
MK_086
As you mentioned one is about adding C Hello world and other is if we have a ready binaries how to add it in rfs.
EBERLAZARE_I_Intel
Thanks, I am still checking the steps on my side to test.
EBERLAZARE_I_Intel
I am still working on this issue, please allow me some time to work on it, I shall get back to you.
EBERLAZARE_I_Intel
I just got the build finished, apologies it took some time, however I currently do not have board access this week as we are having public holiday until Tuesday next week.
In the mean time, could you create another separate case with title, "run hello world in custom rootFS for agilex" etc as the case was for eMMC out of box booting.
MK_086
EBERLAZARE_I_Intel
Thanks for the update. As the initial question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
