Programmable Devices
AN477 Question
GDeXi
 Hello,  I just  feel strange with AN477 doc below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an477.pdf
page 12
 why the
      Calculated output maximum delay =  tsu of external register = –0.9 ns
 is not -tsu of external register ?
 or  = 0.9 ns ?
 thanks for your help
KennyTan_Altera
This is because
1) The multicycle assignments are used to create a setup relationship of 0ns and a hold relationship of -1/2*period.
2) The value for set_output_delay -max is now negative due to the 0ns setup relationship set by the multicycle then the setup requirement (max data delay).
KennyTan_Altera
This is because
User1574410249703619
Listening to you is better than reading ten years!!! Thanks。
GDeXi
Sorry,
I have thought for a long time, but I still don't understand. Could you describe it in detail? thank you
KennyTan_Altera
Any update?
For personal reasons, I'm sorry to reply you so late.
For AN411,I have read page 32.
I can understand why Multicycle set , for same edge launch and latch. I don't  understand why max data delay now is negative.
Q1:
   i don't understand max data delay is negative has some related to Multicycle. and why data delay is negative.
Q2:
  Is it analyzed according to this formula?
I'm sorry for the trouble!
Have a good day.
