Programmable Devices
21602 Discussions
About JESD204b pin constrains
allen18
New Contributor II
Hi:
      I am using the Stratix 10 H-tile series FPGA, and for the JESD204B IP core, I found that in the example design, the voltage standard for rx data and refclk are constrained to CML. However, the refclk I am currently using is source from LMK00301, which cannot output a clock with CML standard. Can I constrain the data as CML, but constrain the clock as HCSL? Compile can passed.
ZH_Intel
Hi Allen,
Good day.
Regarding to your question, yes LVDS and LVPECL will be better than HCSL.
Hope this answers your question.
Thank you.
ZH_Intel
ZH_Intel
Hi Allen,
Thank you for reaching out.
Apologize for the delayed response.
Just to let you know that Intel has received your support request and currently we are confirming the details with our internal team.
I shall come back to you with findings.
Thank you for your patience.
ZH_Intel
ZH_Intel
Hi Allen,
Good day.
Based on the discussion with internal team, you may constrain the data as CML and constrain the clock as HCSL but it is not recommended by Intel as it will impact timing.
By doing so will have risk.
For JESD204 IP, it is advisable to connect direct Tx to Rx.
Thank you.
ZH_Intel
allen18
New Contributor II
Thank you for your reply.
If I constrain the clock as lvds or lvpecl will be better than hcsl ?
ZH_Intel
Hi Allen,
Good day.
Thank you.
ZH_Intel
ZH_Intel
Hi Allen,
Good day.
Thank you for your respond on accepted solution.
Do you still have further inquiries on this case?
If there is no further inquiries, I will transition this thread to community support.
Thank you.
ZH_Intel
allen18
New Contributor II
Thank you,I plan to try to constrain the clock to LVDS and constrain the data to CML, no further inquiries
ZH_Intel
Hi Allen,
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Stay safe, and I hope you have a great day.
Thank you.
ZH_Intel
