Hi all,
I want to build one i3c prototype on fpga, but I find that all pins can only used as one of the push-pull or open-drain, I don't find that one pin can switch drive mode between push-pull and open-drain, anyone can provide me some advice, thanks.
Lambert
Thank you for contacting Intel community.
May i know what is the device number for the FPGA?
Aiman
Hi airman,
I have cyclone v, arria v, arria 10, cyclone 10 board, but I don’t find which one can fulfill my need, or can you provide some advice or fpga kind which can resolve my problem, thanks.
Lambert
You'll find in FPGAs the operating characteristics of a pin are not dynamically settable (ie, LVCMOS vs LVTTL vs LVDS, etc), dynamic pullups, bus hold, totem-pole vs open collector. They can be programmed at startup but are hard (but not necessarily impossible) to change dynamically.
A driver enable can enable/disable the driver function, but it is an all or none option.
Simplest is probably to assign two adjacent pins, an open collector driver with enable, and a totem-pole driver with enable. Then chose one to sample input on, and enable one driver or the other as needed.
So maybe I can use this method currently, and will such pins appear in new FPGA models in the future?
B.R,
Lambert
Since I don't work for Intel/Altera, I can't make any comment on this other than 'not likely', in my opinion.
The usage scenario is quite small for this feature, and using two pins vs one is not a big deal in that case.
It is not like you are going to build a controller that needs hundreds of 'I3C' interfaces.
