Programmable Devices
公告
21615 讨论
Agilex F series ICCMAX of all power rails
fupwang
初学者
1,535 次查看
Do Intel has a peak current data for system develop engineer? I know the PTC tool, but looks it need many infomations from FPGA project. I can not make sure the data filled is exact as a system role. Just want to know the peak data of all power rails current. I select AGFA027R25A2E2V as FPGA device. wish your reply.
0 项奖励
9 回复数
AminT_Intel
员工
1,524 次查看
Thank you for posting a question here and I'm happy to help! But first I will need to understand your inquiry a little bit more. Can you elaborate what data you are looking for?
Thank you.
0 项奖励
fupwang
初学者
1,516 次查看
Hi AminT
    Thanks for your reply. I am asking for the maximum current numbers of all power rails of Agilex F series device AGFA027R25A2E2V. I know Intel suggests to use PTC tools to calculate a pretty accurate data. But I try the PTC and looks it need many output datas from verilog project. And I just want the peak numbers not the exact numbers that followed the real FPGA project. The numbers are like VCC/VCCP-->52.2A peak, VCCR_CORE-->4.5A. Guess Intel should have the data about how large the numbers of all power rails are when they cost the maximum power consumption. thanks.
0 项奖励
fupwang
初学者
1,492 次查看
Anyone from Intel can help this?
0 项奖励
AminT_Intel
员工
1,482 次查看
You can calculate field-programmable gate power consumption for Intel Agilex devices using the Intel FPGA Power and Thermal Calculator, and for more accurate power estimation, use the Power Analyzer in the Intel Quartus Prime Software. Intel recommends that you switch from the Intel FPGA Power and Thermal Calculator to the Power Analyzer once your design is available.
Do you have full design? We would recommend you to use Power Analyzer inside Quartus if you have your design.
Thank you.
0 项奖励
fupwang
初学者
1,474 次查看
Hi AminT
    I know about PTC. it need more data from verilog project. I just need a maximum data for power design. Do intel have these data?
0 项奖励
AminT_Intel
员工
1,469 次查看
Do you have full design or not?
0 项奖励
fupwang
初学者
1,467 次查看
Hi
    I do not have a full FPGA design. Want to assess power consumption before starting board design and FPGA design.
0 项奖励
AminT_Intel
员工
1,423 次查看
We cannot assume the maximum current because different design requires different current consumption. Thus, the only way for you to know the value is to have your full design ready.
Thank you.
0 项奖励
AminT_Intel
员工
1,406 次查看
 We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
0 项奖励
回复
