Programmable Devices
21602 Discussions
Agilex7-I DEV kit CXL Example Memory Change Problem
agilex7
Hi
I'm creating cxl design using cxl example design supporting quartus
Below is our test enviroment
Test Enviroment
- Agilex DVE Kit : Agilex7-I DK-DEV-AGI027-RA
- Server : Intel CRB SPR CRB (CPU D0)
- Quartus version : 24.3
- cxl design : cxl type3 membuffer example design
First we've created cxl type3 example design (16GB memory) by Quartus
and we've seen cxl memory 16GB size in both uefi and linux also mlc test passed in the SPR CRB Server.
And next,  for memory capacity up, we've changed follow item.
- changed Componet dram to DIMM 16GB(Micron x4 RDIMM)  x2 (32GB) via EMIF ip  configuration
- HDM capacity change  16GB --> 32GB ( hardware_test_design/ed_top_wrapper_typ3.sv  & intel_rtile_cxl_top_cxltyp3_ed/ intel_rtile_cxl_top_1120/sim/cxlip_top_pkg.sv mofied) refereced agilex7 cxl de ug ip document
- In the cafu_csr0_wrapper.sv , we've chaged DOE enable to disable
we've couldn't see cxl memory size in both uefi memmap and linux, but we've confirmed Memory Active(good), Media_type(00b) Memory Class(00b) via cxl devsec register in the Linux.
Dose anyone have any experience with this issue ?
RongYuan
Based on "Table 42. Updating HDM Size" in UG, you need to modify several files. Please make sure all these are updated.
Rong
RongYuan
Rong
agilex7
Hi !
Thanks!
I will update all these files !~
RongYuan
If no further questions, I'll transit this case to community support. Thanks.
agilex7
I've solved this issue. I have no questions. Thanks!
