21603 Discussions
Altera MAX 10 and Cyclone 10
miq
Are these Altera parts : 10M08DCV81I7G, 10CL010YU256I7G, 10CL025YU256I7G, 10CL040YU484I7G still active or to be obsolete soon? There seem no stock available in the market, what are the supply plan?
AqidAyman_Intel
Yes, you are correct.
Aqid Ayman
ak6dn
Valued Contributor III
The MAX10 and Cyclone10 families are both pretty new and should be in production for likely the remainder of this decade.
But welcome to 2022. Most semiconductors are severely supply constrained. Most distributors are out of stock.
Virtually all production is going to big customers with pre-negotiated supply contracts.
Off the shelf distributors are usually low man on the totem pole when it goes to allocation.
Consensus seems to be at sometime in 2023 or possibly 2024 things should get back to normal.
Most distributors are not even accepting back orders at this point as they don't expect to see any parts this year.
miq
Thank you. Managed to in touch with the distributor.
Farabi
MAX10 and C10 are new products and production is still active.
You may check with your local distributors to get the allocation to your orders.
Current lead time is pretty long, please expect ~50weeks.
This global supply issue is expected to be recovered by next year.
regards,
Farabi
miq
Thanks, Farabi. Managed to in touch with local distributor.
another question - is this the legit MAX10 marking?
AqidAyman_Intel
Hi Mei Loo,
Did the answer provided helps you? Please let me know if you need other information.
Aqid Ayman
Farabi
Hi Aqid,
need your help to forward the top marking to CQE for verification.
thanks,
Farabi
AqidAyman_Intel
Can you confirm the OPN for the Max 10 marking you provided is 10M08DCV81I7G?
Aqid Ayman
miq
AqidAyman_Intel
As per checking, yes, it is the correct marking for OPN 10M08DCV81I7G, since WLCSP small package we only mark the device name as 10M08V81G.
Aqid Ayman
miq
Hi Aqid,
Thank you for confirming the marking.
Final question, the round dot is representing the Pin 1 orientation regardless of tray or reel packaging, right?
AqidAyman_Intel
Aqid Ayman
AqidAyman_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Thank you.
