Hi everyone!
When i start simulation in quartus the following error message appear: "(vsim-3601) Iteration limit 5000 reached at time 0 ps" My testbench is:
`timescale 1 ns/ 1 nsmodule buffer_vlg_tst();
reg CLK_50MHz;
wire data_out;
buffer i1 (
.CLK_50MHz(CLK_50MHz),
.data_out(data_out)
initial
begin
CLK_50MHz=1'b1;
$display("Running testbench");
forever# 20 CLK_50MHz= ~CLK_50MHz;
end
Any thoughts would be very helpful. Thanks!
whats the code inside the buffer module?
--- Quote Start --- whats the code inside the buffer module? --- Quote End --- The code is:
macromodule buffer (
input CLK_50MHz,
output data_out
wire data_count;
counter count (
.clock(CLK_2KHz),
.q(data_count));
pll my_pll (
.inclk0(CLK_50MHz),
.c0(CLK_2KHz),
.c1(CLK_8KHz));
serializer serial (
.clk(CLK_8KHz), /*start,*/
.inp_data(data_count),
.out_data(data_out),
.capture(CLK_2KHz));
endmodule
module serializer(clk, inp_data, out_data, capture);
input clk, capture;
input inp_data;
output out_data;
reg counter;
reg out_data;
reg temp_data;
always @(posedge capture) temp_data <= inp_data;//input data bufferization
always @(posedge clk)
begin
counter <= 2;
counter <= counter + 1'b1;
end
begin
case(counter)
2'd0: out_data <= temp_data; //2
2'd1: out_data <= temp_data; //1
2'd2: out_data <= temp_data; //4
2'd3: out_data <= temp_data; //3
endcase
end
endmodule
Tricky, the code is:
input CLK_50MHz,
output data_out
wire data_count;
counter count (
.clock(CLK_2KHz),
.q(data_count));
pll my_pll (
.inclk0(CLK_50MHz),
.c0(CLK_2KHz),
.c1(CLK_8KHz));
serializer serial (
endmodule
input clk, capture;
input inp_data;
output out_data;
reg counter;
reg out_data;
reg temp_data;
begin
counter <= 2;
end
begin
case(counter)
endcase
end
endmodule
You have a forever statement inside the initial block. The initial block is for things that happen at time 0. You can't have something go on forever at time 0.
--- Quote Start --- You have a forever statement inside the initial block. The initial block is for things that happen at time 0. You can't have something go on forever at time 0. --- Quote End --- In a testbench, initial blocks can be used to drive stimulus during simulation for example - a reset:
initial begin
rst = 1;
repeat(5) @ (posedge clk) ;
rst = 0;
end
But the OP has generated the clock incorrectly. By using# 5 on the assignment, you only delay the assignment, not the loop, causing the 5000 iteration limit as it is trying to assign the clock at time zero. To do it correctly in an inital block:
inital begin
forever begin
# 20;
end
end
