21615 Discussions
Are there any know issues dynamically configuring the Arria10 IOPLL?
RClan
I have an IOPLL in my design with the associated reconfig block. I am able to reconfigure the counters associated with clock output 0 and see that reflected in the clock 0 output frequency. I am not able to do the same for other outputs of the same PLL. The divide values on the other outputs seem to be stuck at there initial values even though I am able to read back the new values that I have configured them to.
Thanks in advance.
Bob
SreekumarR_G_Intel
Hello Bob, Can you try to reconfigure one PLL output at a time ? Thank you, Regards, Sree
RClan
I have tried this to no avail and have opened a case (00436041).
SreekumarR_G_Intel
sure bob,
