21597 Discussions
Soc EDS DS-5 vs regular DS-5
RShal4
Is the DS-5 which is part of Soc EDS is actually a regular DS-5 ?
I mean, can I install EDS and then change to another "regular" DS-5 install ?
ranran
FawazJ_Altera
Hello, It is the same, the only difference is, the DS5 that is coming with the SoCEDS is loaded with some plugins that will help you to develop your application on Intel SoC FPGAs. Thanks
RShal4
Thank you very much.
Does it mean we can first install DS-5 and then just add the plugin ?
Thanks!
FawazJ_Altera
ARM wise, you can use the tool. However, these plugins are not available online, you need to install SoCEDS to get them.
