Programmable Devices
21615 Discussions
Are they pin-compatible
hi,i used Cyclone4 EP4CE6E22,and EP4CE10E22 is good,are they pin-compatible,who can tell me,thank you!
Check the data!
fwxu,
they may or may not be pin compatible, depending on which pins your design uses.
The best way to check is to select both as migration devices and compile your design.
