21593 Discussions
Arria II GX configuration from CPLD
nome
I am using the JS28F256M29EWH NOR Flash with only using 8-bit data and 25-bit address Parallel Flash in FPP mode. In my case, our flash 8-bits flash data pins are directly connected with fpga_config_data's 8-bit pins. Mostly, these pins I recognize are connected with CPLD, and another set of CPLD pins is connected with fpga_config_data for configuration.
I am following the instructions from ug_pfl.pdf to convert our .SOF to .POF. For NOR Flash programming, I am using the PFL Mega core IP in Mode "only Flash programming" from Arria II FPGA I check read back by using  option bits
Now, I am attempting to configure Arria II GX with CPLD EPM240T100I5 without PFL using Config_Control_Codes from Intel Altera Stratix II.
Please find the attached file.
The issue is that the code doesn't work. I am checking fpga_dclk and fpga_nSTATUS pins using an oscilloscope, but no activity is showing. This implies that there might be a problem with RESET_n and MAX_EN as given in the VHDL Codes.
Also, I have defined unused pins as "As Output Ground"
Please help me identify where I am making a mistake.
Nome
NurAiman_M_Intel
Thank you for contacting Intel community.
What do you mean by "configure Arria II GX with CPLD EPM240T100I5 without PFL using Config_Control_Codes from Intel Altera Stratix II"? What is the reason on using Config_Control_Codes from Intel Altera Stratix II for Arria ii?
What Quartus version do you used?
Any error shows?
Aiman
nome
Thank you for your reply.
What do you mean by "configure Arria II GX with CPLD EPM240T100I5 without PFL using Config_Control_Codes from Intel Altera Stratix II?
I am not utilizing PFL (parallel flash loader) due to the limited LE (logic element) blocks available, as the EPM240T100I5 CPLD has only 240 blocks. This restriction prevents the use of a higher-density CPLD.
We need to allocate more space for various functionalities, aside from FPGA configuration. This is why we are using the official config_control_codes from Stratix, as indicated in the attached QAR file in my initial post.
All specific pin requirements, such as fpga_addr, fpga_nSTATUS, fpga_dclk, and others, have been assigned according to our custom board specifications. However, the issue is that these codes are not working; when testing fpga_dclk from the oscilloscope, it remains low at all times.
Nome
NurAiman_M_Intel
  • Is JTAG working fine? (without config control codes)
  • Where did you get the Config control codes? Is it from Intel or other source?
  • Can you provide us your schematic?
nome
Thanks for your Reply
                           Is JTAG working fine? (without config control codes)        Yes Excellent Working i can get CPLD and  FPGA in quartus programmer even I can get Flash when I load as per our board pins assignment PFL (prallel flash loader) .sof file into FPGA can easily flash programming .
                                Where did you get the Config control codes? Is it from Intel or other source?        yes From Intel official site
Nome
NurAiman_M_Intel
Please provide the link to the Config_control code page so we can do the checking.
Aiman
NurAiman_M_Intel
Any update for this case?
Aiman
NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
nome
I apologize for the delayed response due to my long vacations.
Please find attached our configuration area schematic pdf .
Could you please assist me in identifying any errors, such as incorrect addresses entities?
I'm uncertain about the correctness of the configuration. also suggest us if i will consider PFL  prallel flash loader
Nome
