20400 Discussions
Arria10 GX design example of 40GE ethernet usgae ?
JET60200
We use A10GX device. We need to support 40GE interface.
Is there any 40ge design example in intel design store to begin with ?
Thanks very much~
Deshi_Intel
HI,
Below is A10 Eth 40G design example link
You can always checkout below link for Intel FPGA Ethernet solution support plan and design example link.
dlim
JET60200
Hi @DeshiL_Intel​ , I don't find where the 40ge example design *.qar is. can you share me ? Thanks ​
Deshi_Intel
Hi Jet,
You probably miss out the design example doc guideline (page 6, figure 1-5)
The example design is not attached is the doc. User can basically just click "generate example design" button in LL 40GbE IP to generate the example design.
dlim
Deshi_Intel
Hi Jet,
I hope you are able to generate the design example successfully based on my earlier feedback.
For now, I am setting this case to closure.
dlim
