I need a little advice/direction regarding connecting two fpgas via a bus. HW setup Stratix III (DE3) Stratix V 8 x LVDS Tx pairs ---------------------> 8 x LVDS Rx pairs Any other I/O requirement for signaling is flexible. But for data, the DE3->Stratix V is limited at these 8 LVDS pairs. The bus has to be capable of running at around 10g in total. i.e. around 1.2-1.4Gbps per LVDS pair. Data is mainly from the DE3 to the Stratix V. Ideally I would like to have seamless Avalon interfaces on both sides. Can a dual-clock Avalon ST Fifo span across to the other FPGA via the AltLVDS megafunction? e.g. On the Stratix III (DE3) I configure the Dual Clock Fifo I use the SGDMA(scatter gather) to take data and Stream it out to a Dual Clock Fifo using Avalon ST. I export the signals of the output side of the Dual Clock Fifo. I connect the signals to the alt-lvds Tx megafunction. The valid signal of the FIFO will act as the LVDS Clock for the transfer. On the Stratix V side. I receive the data via the alt-lvds Rx megafunction. I put it in another Dual Clock FIFO and another SGDMA to read the data. Can all this achieve around 10G.. Comments and suggestions (or complete alternate methods) welcome. Regards Zubair- Tags:
- lvds
Try it and see.
Since the ALTLVDS interface will be serializing and deserializing data, you will also need a frame clock. If your data can accommodate some 'extra' symbols, then you can convert the Avalon-ST start-of-packet, end-of-packet, etc, wires into symbols in the data stream. This is how the JTAG-to-Avalon-ST interface works - read the following for details http://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_jtag_to_avalon_analysis.pdf http://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_jtag_to_avalon_analysis.zip This might give you a few ideas. Cheers, Dave- Mark as New
Yes. I will need a frame clock as well. I think I missed it out and its available in the hardware layout as well. Will double check.
Also, I checked the Avalon ST spec. It has a valid signal. This should be usable to generate the frame clock using the Alt-lvds megafunction itself. Thank-you. Seems there are no obvious mistakes.. I guess I'll go ahead and play. Cheers Zubair
