21615 Discussions
BUS TOOL Question!
Hi !
I'm using bus tool for the first time and had a bit of a problem. Lets say i have two blocks(Black A and B) consisting of 3 IO. Block A has 3 outputs as of [3..0] and Block B has 3 inputs which receives in [3..0]. So when i attach the bus how should i label it? is there a certain way?
I do know if i want to attach output pins to any bus i have to label the bus and the pins accordingly. But i'm stuck on just connecting two blocks! Please see my attachment !
Thanks !
first of all.
your name is OK.
you don't need name for a bus which connected directory
like between inst0 and inst1.
also
you can name them like "tmp_bus_a_b[3:0]" etc.
the last one (Bus[0..11])
just cut off bus and wires.
BUS and WIRE can not be connected directory but,each line is connected by there name.
see you.
I forgot one thing.
your bus [3..0] has '4' lines.
I would also use bus indexes [11..0]
