21602 Discussions
Behaviour of MAX without VCCIO supply?
17ADenis
During a structural test of a board with a MAX10 FPGA (manufacturing test, only one time performed), I need to shut-down a DC/DC of the board during about 10 seconds. As a consequence, the core of MAX10 FPGA will be supplied nominally when the all VCCIO not. Is this configuration acceptable for the MAX10? Is there a risk in that situation?
Note : During the test, it is not request that the FPGA is operational.
Denis.
YuanLi_S_Intel
Hi Denis,
It should be fine. The reason is because MAX10 has hot socketing feature which allows the MAX 10 to be removed or inserted during the middle of system operation.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_pwr.pdf (Page 11)
Thank You.
