21615 Discussions
Board design - how to connect VCC_PGM and does it need to be connected to the configuration memory?
MStof1
When VCC_PGM is a separate power supply, does that need to be used on the memory connected to the AS_DATA(3:0) pins?
YuanLi_S_Intel
First of all, may i know which devices you are using?
Thank you.
MStof1
YuanLi_S_Intel
For cyclone V, you may refer to pin connection guidelines as shown below for more information:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/cyclone-v/pcg-01014.pdf
MStof1
The pin connection guidelines do NOT indicate anything regarding what voltage should be used for a configuration memory part!  There used to be references for older parts regarding that.  Apparently, this isn't the case anymore!
YuanLi_S_Intel
For configuration device, may i know which device you are using? if it is third party, you may need to refer to their datasheet.
MStof1
The configuration part is a Micron S25L128SAGMFI011.  Their data sheet just talks about voltage levels, not whether the voltage needs to be the separate programming voltage for the FPGA.  What does the FPGA expect regarding those EPCQ data inputs??  I remember that the Stratix III parts had reference designs that showed that the configuration part needed to use the same voltage source as the programming pins.  I am unable to find anything similar for the Cyclone V parts.
YuanLi_S_Intel
You may find the information such as configuration pin's voltage and connection in our pin connection guidelines user guide.
For cyclone V, it is as attached:
Thank You
YuanLi_S_Intel
Sorry the message continues here:
The voltage for every pin including the bank and powerail for main power pin can be found from page 40.
For cyclone V configuration pin, you may take a look at our handbook:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-v/cv_5v2.pdf (page 253)
MStof1
Page 253 of the handbook has the information I'm looking for.  Thank you.
