Programmable Devices
공지
21615 토론
CPLD MaxII, pull up resistor and led
명예로운 기여자 II
1,843 조회수
Hello
I have to drive 26 Leds through the CPLD MaxII.
I have seen that this CPLD have internal pull up resistor that can be enable or not and apparently we can choose their value.
My question is: can we use those resistor for current limitation?
0 포인트
5 응답
명예로운 기여자 II
973 조회수
--- Quote Start ---
--- Quote End ---
No, they are fixed. Output drive strength can be selected low or high. But you'll normally need external current limiting resistors to set the current of connected LEDs.
0 포인트
명예로운 기여자 II
973 조회수
Ok thanks.
So have you any idea to avoid the use of 26 resistors?
I think about implementing a led driver in the CPLD but I'm not sure that it will decrease my number of resistor.
0 포인트
명예로운 기여자 II
973 조회수
If you don't need high average LED currents, multiplexing the LEDs in a matrix can save output pins and resistors. Using common chip resistor arrays, 26 shouldn't be a problem, however.
0 포인트
명예로운 기여자 II
973 조회수
The maximum forward current is 50ma. I will use PWM to drive the LED.
Do you think it is ok for multiplexing.
I don't know what is multiplexing and how to do that in the CPLD, I am a begginer. I will check that (but if you want or have time to explain feel free :)).
The other proof that I am a begginer, is that I didn't know what was a common chip resistor (I've already check).
Thanks for your help
0 포인트
명예로운 기여자 II
973 조회수
You should also check a respective application note http://www.altera.com/literature/an/an286.pdf
The maximum pin current is specified with 25 mA.
Chip resistor array like http://www.farnell.com/datasheets/467947.pdf
0 포인트
응답
