Hello
I have to drive 26 Leds through the CPLD MaxII. I have seen that this CPLD have internal pull up resistor that can be enable or not and apparently we can choose their value. My question is: can we use those resistor for current limitation?Link Copied
--- Quote Start --- apparently we can choose their value --- Quote End --- No, they are fixed. Output drive strength can be selected low or high. But you'll normally need external current limiting resistors to set the current of connected LEDs.
Ok thanks.
So have you any idea to avoid the use of 26 resistors? I think about implementing a led driver in the CPLD but I'm not sure that it will decrease my number of resistor.- Mark as New
If you don't need high average LED currents, multiplexing the LEDs in a matrix can save output pins and resistors. Using common chip resistor arrays, 26 shouldn't be a problem, however.
The maximum forward current is 50ma. I will use PWM to drive the LED.
Do you think it is ok for multiplexing. I don't know what is multiplexing and how to do that in the CPLD, I am a begginer. I will check that (but if you want or have time to explain feel free :)). The other proof that I am a begginer, is that I didn't know what was a common chip resistor (I've already check). Thanks for your help- Mark as New
You should also check a respective application note http://www.altera.com/literature/an/an286.pdf
The maximum pin current is specified with 25 mA. Chip resistor array like http://www.farnell.com/datasheets/467947.pdf
