Programmable Devices
21613 Discussions
CPLD with Skylake CPU via eSPI interface
I own a project and there is a Altera CPLD attached to Skylake CPU via eSPI, Im wondering port a embedded Linux to access CPLD.
Im sure there is a master CPLD driver build-in Linux kernel, should I write a customize eSPI slave driver for accessing this specific CPLD?
I trace the source code of linux kernel, there is a C file - spi-altera.c, did it support all Altera product and using eSPI interface?
--Dirk
--- Quote Start ---
--- Quote End ---
Most likely, yes.
--- Quote Start ---
--- Quote End ---
That driver is for interfacing to the Altera SPI IP block (e.g. from a NIOS or ARM), which is not what you are doing.
