Programmable Devices
21611 Discussions
CRC blocks 0 / 1 (Fitter Resource Usage Summary)
I'm using Quartus II 9.1sp2, and compiling for a Cyclone II EP2C5T144C8.
In the Fitter Resource Usage Summary it lists an entry that says:
CRC blocks: 0 / 1 (0%)
In the design options I already turned on the automatic periodic integrity check.
The question now is, what is this unused CRC block, and how could I make use of it?
See Application Note 539.
AN 539: Test Methodology of Error Detection and Recovery using CRC in
Altera FPGA Devices.
Page 7:
Using the Error Detection CRC Feature.
You can use a "CRC Block WYSIWYG Atom" to interface from
user logic to the error detection circuit.
There is a Template under "C:\altera\81\quartus\libraries\vhdl\wysiwyg
-- cycloneiii_crcblock parameterized megafunction component declaration
-- Generated with 'mega_defn_creator' loader - do not edit
component cycloneiii_crcblock
generic (
lpm_type : string := "cycloneiii_crcblock" );
port (
clk : in std_logic := '0';
crcerror : out std_logic;
ldsrc : in std_logic := '0';
regout : out std_logic;
shiftnld : in std_logic := '0'
end component;
