I'm using Quartus II 9.1sp2, and compiling for a Cyclone II EP2C5T144C8.
In the Fitter Resource Usage Summary it lists an entry that says: CRC blocks: 0 / 1 (0%) In the design options I already turned on the automatic periodic integrity check. The question now is, what is this unused CRC block, and how could I make use of it?Link Copied
See Application Note 539. AN 539: Test Methodology of Error Detection and Recovery using CRC in Altera FPGA Devices. Page 7: Using the Error Detection CRC Feature. You can use a "CRC Block WYSIWYG Atom" to interface from user logic to the error detection circuit. There is a Template under "C:\altera\81\quartus\libraries\vhdl\wysiwyg" ------------------------------------------------------------------ -- cycloneiii_crcblock parameterized megafunction component declaration -- Generated with 'mega_defn_creator' loader - do not edit ------------------------------------------------------------------ component cycloneiii_crcblock generic ( lpm_type : string := "cycloneiii_crcblock" ); port ( clk : in std_logic := '0'; crcerror : out std_logic; ldsrc : in std_logic := '0'; regout : out std_logic; shiftnld : in std_logic := '0' ); end component;
