Programmable Devices
21594 Discussions
CameraLink with Cyclone IV GX
I'm looking at making a CameraLink transmitter using the GX transmitter blocks in the Cyclone IV. ALTGX won't allow me to select a channel width of 7 which is the serialization factor. Is this an inherent limitation?
See Figure 1-3 of the transceiver manual: https://www.altera.com/en_us/pdfs/literature/hb/cyclone-iv/cyiv-52001.pdf
The "Byte Serializer" is the "inherent limitation".
CameraLink is very easy to implement just using ALTLVDS and LVDS I/O pins, with obvious limitations of the I/O pin capabilities.
Thanks ted. Yes, using ALTLVDS would be simpler, it's the "obvious limitations of the I/O pin capabilities" I'm worried about. CameraLink at 85Mhz requires an I/O toggle rate of ~298Mhz. The Cyclone IV I7 device specifies a max toggle rate of 370Mhz for true LVDS, I guess this is OK. The output jitter is 500ps p-p max, which is about 30% of UI. This seems like a lot, maybe OK.
I also have to consider adding LVDS buffers to the FPGA to protect it from the "outside world". Given that, I might as well just use a CameraLink transmitter chip (DS90CR287) and save myself the FPGA coding. The GX outputs seemed like an elegant solution to all the above, plus I gets some extra features like programmable output level and pre-emphasis. These are the tradeoffs I'm struggling with at the moment.
Thanks for posting this question. I am doing the same thing. This is post was very helpful to me. Joe
Glad it was useful. I ended up using the DS90CR287.
thanks for the sharing.
Hi, have a question that I hope someone can answer. I'm looking at the DS90CR287 device and also the document "Camera Link: Specifications of the Camera Link Interface Standard for Digital Cameras and Frame Grabbers". On page 2-1 they mention four enable signals: FVAL, LVAL, DVAL and Spare. However, I don't see these as inputs on the DS90CR287 device. How to I add these four signals?
Next, I have two video streams each stream has its own clock. I assume that I will need two DS90CR287 devices and according to page 5-2 it looks like I could use only one MDR-26 pin connector, but that does not agree with page 3-1. What am I missing here?
joe
See table 4-1 for the mapping of FVAL, etc. to the DS90CR287 pins. Note also the strange mapping of data bits.
Two video streams with independent clocks will require two DS90CR287s. I see your confusion regarding pages 5-2 and 3-1. I'm not aware of any frame grabbers that will support two, independent CameraLink inputs with different clocks on the same MDR-26 connector. They may be out there though.
Thank you so much. Now things make sense. One more question. My video image is 14-bits per pixel, so what do I do with the unused bits, tie to ground? Thanks, Joe
CameraLink supports 14 bit monochrome in the Base configuration (Table C-1). Unused inputs on the DS90CR287 should be grounded.
That's even better. I'm looking at Table 5-1 for the Base Config. and please correct me if I'm wrong here. I would connect the DS90CR287 to Channel Link Signals X0+-, X1+-, X2+- and X3+-? Now what should I connect to SerTC+-, SerTFG+-? I'm connecting to a CCD detector and the fpga will drive the DS90CR287. I'm only getting image from the CCD and not communicating with it.
Yes, use X0, X1, X2, X3 and XCLK. If you're not using communication then simply float SerTC and SerTFG as well as the CCx signals..
