21600 Discussions
Can industrial devices use the same configuration file as their commercial counterpart?
GSzak1
I'd like to substitute an industrial grade Cyclone V part in an existing design due to better availability. Do these parts need a different configuration file, or can I use them interchangeably? The specific part numbers are:
5CGXFC9E6F31C7N
5CGXFC9E6F31I7N
where the only difference in the part number is "I" vs "C"
Thanks and regards,
Gabor
ak6dn
Valued Contributor III
Same configuration file. Same die. Just tested differently to guarantee operation over a wider temp range.
ak6dn
GSzak1
Thanks for the help. That was my guess, but I didn't want to take a chance and then find out that the device ID is different, requiring a tool re-run. At the moment I have the config file built for the commercial part and no license to re-build the design.
