21609 Discussions
Can't generate program files
Avichay
I'm trying to compile the hard ip ethernet 10G example design .
"F-Tile Ethernet Intel® FPGA Hard IP" example design for 10GBE standalone
but cant generate sof file. i get all the time this message attached.
ZiYing_Intel
Hi Avichay,
Please do ensure the OPN number in the Quartus is same as the board that you use.
zying
ZiYing_Intel
Hi Avichay,
zying
Avichay
Thanks for your reply.
 I am trying to check the example design on my board with my QSF file.
I'm using AGFB027R24C2E2V FPGA.
This part is i the project and in the qsys setting part from where i generated the example design.
should i generate the example design with the ANLT (Auto negation and training disabled ? )
my purpose is to check the xcvr  and ethernet using loop back on the Intel toolkit system console .
I should have all the licenses.
sstrell
As the error states, you don't have a license for this IP.  If you think you do, verify under Tools -> Options.
ZiYing_Intel
Hi Avichay,
Can you provide:
1)   Screenshot of message error
2)   Screenshot of Quartus >>tools>>license setup
zying
ZiYing_Intel
Hi Avichay,
Thanks for marking my suggestion as a solution. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Best regards.
zying
