I am running Red Hat Enterprise Linux 6 64bit. I have followed the instructions here:
http://www.altera.com/download/drivers/dri-usb_b-lnx.html I have set the QUARTUS_ROOTDIR path like this: export QUARTUS_ROOTDIR=/root/altera/13.0/qprogrammer Yet, I still get this error when browsing for the USB blaster "Error: QUARTUS_ROOTDIR is not set" What else can I try? Thanks.Link Copied
For the sake of helping others, I started DS-5 like this from the same terminal.
export QUARTUS_ROOTDIR=/home/altera/13.0sp1/qprogrammer export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/home/altera/13.0sp1/qprogrammer/linux /home/altera/13.0sp1/embedded/ds-5/bin/eclipse & After this it worked.- Mark as New
Thank you bobo01 ... that was helpful! :-)
