Programmable Devices
21618 Discussions
Cent OS 6.2 Support
Does anybody knows when support for CenOS 6.2 will be available?
I am already using 6.2 but in website the supported OSs are only 4 and 5.
I have subscription full license.
--- Quote Start ---
--- Quote End ---
I have it installed under 6.2 (32-bit) and it works fine (both web and full editions).
There were no installation issues (unlike Ubuntu).
Cheers,
Dave
Hum, i think i am doing something wrong because there is no way to install even in commanda line. How did you do that? I burned an .iso and autorun does not open. Is there any guide step-by-step to install?
I just took a look and i did not find it. Maybe i will have to take a closer look, but if you know at glance it might help.
Thanks again.
--- Quote Start ---
--- Quote End ---
My notes say;
1) Install 11.1 first
- 11.1_173_quartus_linux.sh
– 11.1_173_devices_cyclone_max_legacy_linux.sh
– 11.1_173_devices_arria_linux.sh
– 11.1_173_devices_stratix_hardcopy_linux.sh
2) Then install the Quartus 11.1sp1 service pack update
– 11.1sp1_216_quartus_linux.sh
3) Then install Modelsim-ASE 11.1sp1
- 11.1sp1_216_modelsim_ase_linux.sh
(No need to install 11.1 Modelsim-ASE first)
Cheers,
Dave
Just one last confirmation:
All was installed with ./ with su right?
Another question:
How to set the display variable with a valid X display for a GUI?
Which X display you are using. I just installed and could not add/remove a X display. I did not work.
Thanks again,
--- Quote Start ---
--- Quote End ---
Yes.
I installed the full edition into /opt/altera/11.1sp1 and the free edition into /opt/altera/11.1sp1_free.
Cheers,
Dave
--- Quote Start ---
--- Quote End ---
Eh? If you are running Centos 6.2 from the GNOME desktop, then you should not have to set any X display. If you have sshed into the Centos 6.2 machine, then use ssh -X <machine>. If you have not installed X at all, then you've likely messed up your Centos install. I'd guess you might want to start again, or perhaps 'yum install gnome' and pickup all the dependencies. Personally, I'd start from scratch to make sure you have a decent Centos 6.2 install. I install a workstation install.
Cheers,
Dave
I am using a software development workstation. I downloaded from centos.org the 6.2 version. I installed everything again and everything was the same. I will try to make all you said now. Thanks again.
--- Quote Start ---
--- Quote End ---
Ok, that sounds like what I installed.
Do you have a graphical desktop, or are you sitting at a command line? If you have a graphical desktop running, then you should have no problems with the Quartus install. You run the script, it pops up the installer GUI, and you follow the prompts.
Cheers,
Dave
Yes i am using a graphical desktop, but the installer GUI does no pop up. I will try to install X.
I tried yum install gnome and it said No package gnome available.
--- Quote Start ---
--- Quote End ---
If you have a graphical desktop running, then you do not need to install X.
--- Quote Start ---
--- Quote End ---
Sorry, I just guessed that the package name would be gnome. You already have a graphical desktop running, so you should just be able to run the install script, i.e.,
1) In the graphical desktop, start a terminal
2) Login as root
3) Run the installer script via
./11.1_173_quartus_linux.sh
or perhaps
bash ./11.1_173_quartus_linux.sh
4) Follow the GUI
Cheers,
Dave
GUI does not start. Wicj mirror you downloaded your centos 6.2? I will try to download again and reinstall.
--- Quote Start ---
--- Quote End ---
I assume you mean the Quartus GUI does not start. You already indicated that the Centos GUI was running fine. There should be no need to reinstall Centos, as you indicate its already running fine.
Why don't you post a screen shot of what happens when you run the Quartus install script in the terminal? Perhaps it'll be clearer what you have done wrong.
Cheers,
Dave
GUI does not show up.
Just one comment: I have a two DVD disk CentOs6.2 install. He does not ask for the second DVD. Maybe if i download the same .iso or file you have i will also have a know copy.
--- Quote Start ---
--- Quote End ---
So what did the log file have in it?
Probably something about the fact that you need to install 11.1 first per my instructions above.
Cheers,
Dave
--- Quote Start ---
--- Quote End ---
It only uses the first .ISO. Your Centos install looks fine.
Cheers,
Dave
