21615 Discussions
Clock Voltage on Max7000
Hi there!
I'm doing a PCB design which includes a microcontroller and a MAX7000 CPLD. As the controller's IOs work on 3.3V we decided to run the MAX7000's IOs also on 3.3V. The core is using 5V
In the MAX7000 datasheet I couldn't find any information about the clock voltage. Can i use a 5V oscillator, even if the IO voltage is on 3.3V?
Thanks for your support
Simon
If you read the MAX7000 data sheet thoroughly, you'll notice:
- Input buffers are supplied from VCCINT and thus independent of VCCIO.
- MAX7000 inputs have a TTL level specification, minimal high level is 2.0 V. 3.3V CMOS and 5V CMOS/TTL levels are fine to drive the inputs, including clock.
Thank you for your advice. In a few days i'll see if it was correct...:)
