Programmable Devices
21615 Discussions
Clock divider
I need to have a continuous clock input to my traffic light assignment. A clock divider from 100MHz to 1Hz is needed. But I dont know how to write the code as I am new to vhdl. Anyone can help? :confused: or is there any other way I can get a continuous clock input so that I can program the code directly to the board.. ? Then the green light represented by green led wil light up for 30s, yellow for 2s..
You can use the Altera Megawizard to generate this logic for your device.
Sounds like you need to have a large counter (25 bits or so) and "and" all the bits together to form an enable for other registers to give you a 1Hz clock rate.
how to use the altera megawizard..
It is in the Quartus menu.
--- Quote Start ---
--- Quote End ---
use a counter and an edge detection in order to generate an enable signal for your register. E.g
module ena_gen (clk,ena_out);
input clk;
output ena_out;
reg [26:0] count;
reg edge_det;
always @(posedge clk) begin
count <= count + 1;
edge_det <= count[26];
end
assign ena_out = !edge_det & count[26];
endmodule
Kind regards
GPK
This is Verilog - he asked for VHDL
--- Quote Start ---
--- Quote End ---
Hi Tricky,
you are right, I should read all posts, but maybe he has now a starting point ...
Kind regards
GPK
--- Quote Start ---
Hi Tricky,
Kind regards
GPK
--- Quote End ---
now the VHDL version. Maybe not the best way for VHDL, but I'm not a VHDL expert.
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_unsigned.ALL;
ENTITY ena_gen IS
PORT
-- Input Ports
clk: IN std_logic;
-- Output Ports
ena_out : OUT std_logic );
END ena_gen;
ARCHITECTURE RTL OF ena_gen IS
SIGNAL count : std_logic_vector ( 26 DOWNTO 0);
SIGNAL edge_det: std_logic;
BEGIN
-- Pulse counter
counter : PROCESS (clk)
BEGIN
IF rising_edge (clk) THEN
count <= count + '1';
edge_det <= count(26);
END IF;
END PROCESS counter;
ena_out <= (NOT edge_det) AND count(26);
END rtl;
Kind regards
GPK
