21615 Discussions
Collection does not exist error while using Timing Analyzer with Intel Quartus Prime Pro 23.3
sgannava
Hi Team,
I have the timing query tcl script. If I run the tcl script in the timing analyzer of Intel Quartus Prime Pro 23.3, I am getting the below error
Error (23035): Tcl error: can't read "slack": no such variable
###Tcl script
create_timing_netlist
read_sdc
update_timing_netlist
report_timing -append
set worst_path [get_timing_paths -npaths 1 -setup]
foreach_in_collection path $worst_path {
set slack [get_path_info $path -slack] }
puts $slack
Few times I got below error also
Error(23035): Tcl error: ERROR: Collection does not exist with name (:internal collection). Specify the collection name returned by a Tcl command that supports "foreach_in_collection." Note a valid collection name can become invalid if the variable holding the collection goes out of scope, as well as a result of some built-in TCL commands, for example, 'string length.'
Sai G
ShengN_Intel
I try to run the script without problem check screenshot:
I try to run each command separately without problem check screenshot:
I think make sure that each previous command can be executed successfully from your side.
Sheng
ShengN_Intel
May I know any further concern or update?
Sheng
