- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Chapter 8 of the Configuration Handbook describes combining different configuration schemes. In the section that describes combining AS (Active Serial) mode and JTAG mode, this chapter indicates the JTAG interface is used to configure the FPGA while the AS interface is used to program the serial configuration device.
In this configuration, can the JTAG interface also be used to program the serial configuration device?
Hal
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thank you for your clarification. For your question, yes it can be. However, you will need to use different bitstream for that. To program the flash device, you will need to generate JIC programming file. To program FPGA, you will need to generate SOF programming file for that.
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Sorry, before we get started. May i know which device are you referring to?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi YuanLi,
I'm referring to a Arria II GX device (EP2AGX65CU17I3G).
Hal
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I am glad that it helps. I am closing this thread. If you feel this is helping you, kindly give me a good rating. Thanks
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thanks for your quick and informative replies! I appreciate it.
Hal
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
