21615 Discussions
Communication with ADC on Cyclone 2
I am wondering if there are any examples on how to communicate with the ADC Chip (WM8731) on the cyclone 2. I understand that the board uses the chip as a slave, but have no idea how to take samples from it.
In the bigger picture, I am connecting my guitar into the mic input of the board and will do some signal processing from there. At the moment, I have no idea how to set up the board correctly. Any suggestions/help?
Do you have a de2/de2-70 board?
if it's your case, take a look to Audio example included in CD-ROM for both boards.
http://www.terasic.com/downloads/cd-rom/ (http://www.terasic.com/downloads/cd-rom/)
I have a Cyclone 2 EPC20F484C7. Not sure what is a DE/DE2-70 board. Sorry.
I have gone through the examples in the CD-ROM but I am very confused with all the code as I am not familiar with Verilog. Also, must we use the NIOS processor to communicate with the ADC? Is it possible to build a block diagram which does the job and if so, where could I find such an example?
Apologies, I am totally new to FPGAs and any help would be appreciated.
hi!
get university program audio core, and audio and video config core... that vil help... contains documentation abt how to use them...
All Terasic Dev Kits with an audio codec come with Verilog demostration code. As far as I understand the code, you can use it without NIOS II. It has a state machine that controls the codec setup (sending several commands). I agree, that the demostration code is far from being instructive.
Hello..ok , let say that I want to call the data which has been digitized by ADC(to modify the data), then how do I do it?
can i do it through software control?
Hi Fantagiro_88,
Do you have any solution to earlier topic that you wrote in 2009?
If you could give a quick answer, it would be much appreciated.
Thanks!:rolleyes:
