Cpld max v - i2s
hello everybody
I'am a beginner at the VHDL programming. I use CPLD Max V (5M570ZF256C5N) in my internship and I have to write a program in VHDL. the program is selection between two audio sources via I2S bus. so I do not know how to write the I2S protocol on quartus
can you help me to solve this problem.
thank you.
1. Collect information about HDL (VHDL, Verilog) languages & I2S protocol like IEEE Papers, Case study, Thesis etc.
2. Study & understand the protocol.
3. Start HDL coding parallel & also go through the Intel online training for HDL & Quartus tool.
Refer the following links & attachment,
https://www.altera.com/support/training/curricula.html
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
thank you Mr vikas
hello vikas
i have read the PDF tha you give me and i searched on the internet. I found the I2S_interface VHDL program. i tried to compile it but I had some error. after resolve the maximum possible of error I still have some of them.
here is the message that says there is an error:
here is the code :
generic ( DATA_WIDTH : integer range 16 to 32; BITPERFRAME : integer ); Modify the code like bellow, generic ( DATA_WIDTH : integer := 32; BITPERFRAME : integer := 0 ); If want to use in the range format then use a signal like a bellow, signal temp : integer range 0 to DATA_WIDTH := 0;
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Best Regards
Vikas Jathar
hello Mr Vikas
I complited the program successfully without error and I did a simulation but I received this result. I think there is a problem.
imad bourja
The screenshot is not visible properly.
Have you provided all input stimulus in Testbench? If not then refer testbench format from Google & check again.
Please open a new thread for better support.
Best Regards
Vikas Jathar
I also found the testbensh of this code.
hello vikas
I simulated the test bench in RTL STIMULUS and I received these results.
I think there is an error in the adc signal.
imad bourja
hello Mr vikas,
finally I had the satisfactory result about I2S. I am based on the documents that you gave me.
this is the simulation on ModelSim.
thank you again .
imad,
