21615 Discussions
can't see enough FMAX
hello
I create one FPGA project with CycloneV( 5CGXFC9E6F35C7 ).
it has 80 pairs of LVDS inputs as DDRIO input.
when I compile the project, it says FMAX is 103MHz that is too slower than I expected.
I need 300MHz.
I tried to compile each 8bits LVDS inputs independently.
then I found that some of them is 260MHz FMAX ( that still not enough by the way. )
the other hand, some other is 103MHz FMAX.
why LVDS input has different FMAX?
I mean this big difference.
do I miss something?
thank you.
What do your SDC timing constraints look like? How is your clocking set up in your design. More details needed here.
hello sstrell.
thanks for your answer.
actually, I do not know SDC file well.
I just wrote those.
for 300 MHz clock is this.
create_clock -name {lvdsclk300} -period 3.333 -waveform { 0.000 1.666 } [get_ports {cam_clk[3]}]
and also for delay, I wrote this statement for pins cam_data[0] to cam_data[79]
set_input_delay -add_delay -clock [get_clocks {lvdsclk300}] 0.000 [get_ports {cam_data[0]}]
