21592 Discussions
Cyclone 10 LP 10CL025 to 10CL006 migration
Zian
Hi !
I'm creating a PCB layout with a 10CL025 U256, and I'm wondering what will happen if I use in the future a 10CL006 U256 instead of this 10CL025 with the same PCB layout :
- This migration means that some 10CL006 IO pins will be directly connected to GND or VCCINT(1.2V) or VCCA(2.5V)
- For information VCCIO = 3.3V (with 10CL006 and 10CL025)
If these IO pins (connected to GND or VCCINT(1.2V) or VCCA(2.5V)) are specified as inputs with no weak pull-up, I need a confirmation that the 10CL006 FPGA will not have an abnormal behaviour with power voltage on these inputs located in the forbidden zone (between Vil and Vih) : as no FlipFlop (and consequently no CLK rising edge) are connected to these inputs, it should be OK ? No metastability or something else wrong ?
Thanks for answering.
sstrell
You can add a migration device in the Quartus project settings.  Then in the Pin Planner, it will let you know if any of your current assignments will be an issue in the migration device.
Zian
Thanks for answering ! I'm already sure that my QSF pin assignments is not an issue because I will not use the IO pins lost in 10CL006 U256 (These pins are connected to GND 1.2V or 2.5V with 10CL025) : I put all these pins in QSF as inputs with no weak pull-up.
I need "a confirmation that the 10CL006 FPGA will not have an abnormal behaviour with power voltage on these inputs located in the forbidden zone (between Vil and Vih) : as no FlipFlop (and consequently no CLK rising edge) are connected to these inputs, it should be OK ? No metastability or something else wrong ?"
EthanLi
Hi Zian,
Please refer to the pin connection guideline for the specific pins like pll/clock pins.
https://www.intel.com/content/www/us/en/docs/programmable/683137/current/clock-and-pll-pins.html
If it is a GPIO pins, it would be OK for leaving it without any pullup or pulldown.
But in general, we suggest to set it as tristate for the safety of circuit.
Ethan
FvM
if you select migration devices in Quartus device configuration, the pins that are optionally connected to VCCINT or GND won't be available for any assignment, also not tristate. You can be pretty sure that Quartus configures the pins as necessary.
The previous questions about possible "abnormal behavior" are redundant as well.
Zian
I've tried : the report of migration tells that those pins are set as "input tristated".
So without setting migration, I can also set those pins to "input tristated".
