21611 Discussions
Cyclone 10GX DDR3 EMIF Clock Input
GLees
New Contributor II
I've instantiated a DDR3 EMIF in banks 2K & 2J (1.5V I/O) of a Cyclone 10GX220 device.  I let Quartus choose the pin locations.  Quartus assigns a differential clock with an LVDS interface for the pll_ref_clk input.  I have two questions;
1.  Can I force Quartus to accept a single ended, 1.5V clock instead?
2.  If not, will the 1.5V I/O bank actually accept an LVDS clock?  Typically a 1.8V I/O bank is used for LVDS signals.
AdzimZM_Intel
"1. Can I force Quartus to accept a single ended, 1.5V clock instead?"
  • Yes the PLL reference clock can be single-ended clock or differential clock.
"2. If not, will the 1.5V I/O bank actually accept an LVDS clock? Typically a 1.8V I/O bank is used for LVDS signals."
  • Yes there are dedicated clock pins in the I/O bank for the PLL reference clock.
  • Setting this clock pin to use LVDS I/O standard should be fine.
Adzim
