I have a Cyclone 2 configured via AS from EPCS4 chip.
How do I force reconfiguration from within FPGA after EPCS4 content update? I do not have the access to the external nCONFIG pin from the inside logic. PszemolLink Copied
try running the megawizard and seeing if you have a remote update core. I don't know if CII has it. CIII does. Search for "remote update" on this blog. There are lots of people asking questions on this subject. Good luck, you will need it.:wacko:
Cyclone II doesn't have the required remote update hardware. As far as I know, there's no means to force a reconfiguration other than asserting NCONFIG pin or through a JTAG instruction.
