DE2_TV problem
In the file of itu_r656_decoder ,what's the affection of " if ((h< 51) || (h > 771)) " and " if ((h< 41) || (h > 781)) "?
And " Vde_counter >31 and Vde_counter <511",why must the Vde_counter larger than 31 ?
`define sync 8'd101
module itu_r656_decoder
input CLOCK,
input [7:0]TD_D,
input TD_HS,
input TD_VS,
input SW0,
input SW1,
output [7:0]Y,
output [7:0]Cb,
output [7:0]Cr,
output reg HSx2,
output VSx1,
output reg Ypix_clock,
output blank
assign VSx1=TD_VS;
/////// FF 00 00 SAV(EAV) //////
reg[7:0]R1,R2,R3;
reg[7:0]RR1,RR2,RR3;
wire Y_check=( (R3==8'hff) && (R2==8'h00) && (R1==8'h00) )?1:0;
always @(posedge CLOCK) begin
RR1=TD_D;
RR2=R1;
RR3=R2;
end
always @(negedge CLOCK) begin
R1=RR1;
R2=RR2;
R3=RR3;
end
/////decode SAV(EAV) ////
reg START,Field;
if (Y_check==1)
begin
START=~TD_D[4];
Field= TD_D[6];
end
end
//////YUV4:2:2 to YUV4:4:4/////
reg [7:0]YY;
reg [7:0]CCb,Cbb;
reg [7:0]CCr,Crr;
reg [1:0]COUNTER;
if (!START)
COUNTER=0;
else COUNTER=COUNTER+1;
end
case (COUNTER)
0:begin Cbb=TD_D; Ypix_clock =0;end
1:begin YY =TD_D;CCr=Crr;CCb=Cbb; Ypix_clock =1;end
2:begin Crr=TD_D; Ypix_clock =0;end
3:begin YY =TD_D;CCr=Crr;CCb=Cbb; Ypix_clock =1;end
endcase
end
///// auto-counting H length ////
reg [10:0]H_COUNTER;
reg [10:0]RH_COUNTER;
if (TD_HS) H_COUNTER=0;
else H_COUNTER=H_COUNTER+1;
end
always @(posedge TD_HS) begin
RH_COUNTER=H_COUNTER;
end
/////to generate HSx2////
if (
((H_COUNTER >= 0) && (H_COUNTER < `sync)) ||
((H_COUNTER >= RH_COUNTER[10:1]) && (H_COUNTER < (RH_COUNTER[10:1]+`sync+1)))
HSx2=0;
else
HSx2=1;
end
/////H blank for HSx2/////
reg [10:0]h;
reg h_tr;
reg h_tr_h;
if(!HSx2) h=0;
else
h=h+1;
end
h_tr=0;
else
h_tr=1;
end
h_tr_h=0;
else
h_tr_h=1;
end
/////V blank for HSx2//////
reg[10:0]Vde_counter;
always@(posedge HSx2)begin
if (TD_VS==0)
Vde_counter=0;
else
Vde_counter=Vde_counter+1;
end
///v-h blank output//
wire vde=((Vde_counter > 31) && (Vde_counter < 511)) ? 1:0;//480
wire blank_h = h_tr & vde;
///vga blank output//
assign blank = h_tr_h & vde;
/////dual port RAM////
wire [7:0]Yw;
wire [7:0]Cwr;
wire [7:0]Cwb;
dul_port_c1024 YYYR(
.iDATA(YY[7:0]),
.iHSYNC(TD_HS),
.iHSYNCx2(blank),
.Y_CLOCK(Ypix_clock),
.Y_CLOCKx2(CLOCK),
.oDATA(Yw[7:0]),
.field(Field),
.VS(TD_VS)
dul_port_c1024 CBB(
.iDATA(CCb[7:0]),
.iHSYNC(TD_HS),
.iHSYNCx2(blank),
.Y_CLOCKx2(CLOCK),
.oDATA(Cwb[7:0]),
.field(Field),
.VS(TD_VS)
dul_port_c1024 CRR(
.iDATA(CCr[7:0]),
.iHSYNC(TD_HS),
.iHSYNCx2(blank),
.Y_CLOCKx2(CLOCK),
.oDATA(Cwr[7:0]),
.field(Field),
.VS(TD_VS)
/////YUV 4:4:4 output////
assign Y = (blank_h)?Yw :8'h10;
assign Cr = (blank_h)?Cwr :8'h80;
assign Cb = (blank_h)?Cwb :8'h80;
endmodule
i also don't understand these. Who can help us ?:-P
