21602 Discussions
Cyclone III Active Serial Configuration
Does anyone know how long it will take to configure a EP3C10 with a EPCS1 using the active serial (AS) configuration? I need the FPGA to be live around 300 ms after power-up, and wanted to know if this is feasible.
Thanks for any response.
I know one of my EP3C25 designs takes approximatly 150 ms after power-up for configuration in active serial mode. (Fast Active Serial Mode I believe)..
Pete
Have a look at this document (http://www.altera.com/literature/hb/cyc3/cyc3_ciii51016.pdf).
You need to take into account the POR time (you'll probably have to use a fast POR, but then, be sure that your power supplies will reach the correct level in time), then you have the configuration itself (page 9-20 gives you a method to estimate the maximum configuration time) and finally the initialization (pages 9-9/9-10) before the FPGA goes into user mode.
--- Quote Start ---
--- Quote End ---
Why would you be concerned that the power supplies are at the correct levels? Won't the FPGA start the POR time (3ms-9ms for Fast POR) once the power supplies have reached their correct levels?
The POR starts when the main power supplies (VccInt, VccA, and the VccIO for the banks that contain configuration pins) reach a certain level (I tried to find those levels, but I can't see them anywhere in the datasheet). Then you have the POR delay to ensure that those power supplies stabilize within the specified range (+/- 5% usually).
