Programmable Devices
21615 토론
Cyclone III stays in POR forever
명예로운 기여자 II
1,487 조회수
I'm using EP3C5E144, and tried download code through JTAG and configuration port without success. I found the pins nSTATUS, nCONFIG and CONF_DONE are all logic low. Does this mean the chip is in Power On Reset? I have +1.2V supply for VCCINT and VCCD_PLL1,2; +2.5V for VCCA1,2, and +3.3V for all VCCIOs. MSEL2 and MSEL0 grounded. MSEL1 is connected to +2.5V. All these voltages are good. What could make the chip stays in POR?
0 포인트
4 응답
명예로운 기여자 II
663 조회수
hi
if i i'm not mistaken ....
nSTATUS, nCONFIG and CONF_DONE have to conect to vcc..... put 10k res...
if you put this pins to gnd your system stay on por
cheers
Franz Wagner
0 포인트
명예로운 기여자 II
663 조회수
restating franz, nCONFIG is an input and should not be low. it should be pulled up by 10K resistor or directly to VCCio. nSTATUS and nCONF_DONE are bidir and they should be pulled up by 10K resistor.
nCONFIG low puts chip in configuration mode. if it is already pull'd up, then i would say you have a short to ground.
0 포인트
명예로운 기여자 II
663 조회수
Thanks, you guys. These pins are pulled up with 10K resisters already.
By reading another thread, I found out that the E-PAD under the chips was not soldered to GND very well (cold-joint). Now the problem has been fixed. Have a good day.:)
0 포인트
명예로운 기여자 II
663 조회수
sounds ......good
:cool:
0 포인트
응답
