21611 Discussions
Cyclone PS Configuration help needed
Hi there,
I have the following setup:
microcontroller <-> Altera Cyclone FPGA
I am trying to configure the FPGA from the microprocessor (passive).
I am using the .rbf file format that I am storing in the flash memory of the microprocessor.
Now this "was" working correctly before but I added some logic to my FPGA design and now the configuration doesn't work. The nSTATUS pin is pulled low after some time, indicating that there is a problem.
Anybody done this before? Can you give me some pointers?
Jacques
I can't really think of any logic changes that would affect this. I would double-check the device options to make sure it is set up with the right configuration scheme and options.
Jake
