21611 Discussions
Reduce Clock Setup and Clock Hold times
Hi there,
I have a state machine witch makes some math operations. The question is how can I reduce the clock setup and hold times, so I can meet my timing requirements? Here is the code of the state machine:
module math_synthesis ( input clk20M, input a, b, output reg result_out ); //Math registers reg dataa_mult, datab_mult, dataa_add, datab_add, dataa_sub, datab_sub, denom_sig, numer_sig; wire quotient_sig, remain_sig, result_add, result_sub; wire result_mult; //State machine registers: reg currentState; //Registers initial: initial begin currentState = 4'd0; end //States: parameter STATE_1 = 4'd0, STATE_2 = 4'd1, STATE_3 = 4'd2, STATE_4 = 4'd3, STATE_5 = 4'd4, STATE_6 = 4'd5, STATE_7 = 4'd6, STATE_8 = 4'd7; always @(posedge clk20M) begin case(currentState) STATE_1: begin dataa_mult <= a; datab_mult <= 16'd977; currentState <= STATE_2; end STATE_2: begin numer_sig <= result_mult; denom_sig <= 16'd1000; currentState <= STATE_3; end STATE_3: begin dataa_mult <= quotient_sig; datab_mult <= 16'd256; currentState <= STATE_4; end STATE_4: begin dataa_sub <= result_mult; datab_sub <= 16'd25600; currentState <= STATE_5; end STATE_5: begin numer_sig <= result_sub; denom_sig <= 16'd100; currentState <= STATE_6; end STATE_6: begin result_out <= quotient_sig; currentState <= STATE_1; end endcase end math_mult math_mult_inst ( .dataa ( dataa_mult ), .datab ( datab_mult ), .result ( result_mult ) ); math_divide math_divide_inst ( .denom ( denom_sig ), .numer ( numer_sig ), .quotient ( quotient_sig ), .remain ( remain_sig ) ); math_add math_add_inst ( .dataa ( dataa_add ), .datab ( datab_add ), .result ( result_add ) ); math_sub math_sub_inst ( .dataa ( dataa_sub ), .datab ( datab_sub ), .result ( result_sub ) ); endmodule
I attached the clock setup and hold times.
If there is any technique witch I could use to improve timings, please share it :)
--- Quote Start ---
Hi there,
--- Quote End ---
what is your required clock speed ? How do you generate the clock (PLL ?).
Kind regards
GPK
My clock speed is 20MHz but if I want to do more complicated calculations or change the signals width it doesn't fit. It's generated by external oscillator.
VT
--- Quote Start ---
VT
--- Quote End ---
Hi VT,
did you write your arithmetic functions by yourself ?
Kind regards
GPK
--- Quote Start ---
Hi VT,
Kind regards
GPK
--- Quote End ---
The math functions are asynchronous, generated by Altera's MegaWizard Plug-In.
By the way what does the following warning mean:
Warning: Synthesized away the following LCELL buffer node(s): Warning (14320): Synthesized away node "math_mult:math_mult_inst|lpm_mult:lpm_mult_component|mult_k3n:auto_generated|le10a" Warning (14320): Synthesized away node "math_mult:math_mult_inst|lpm_mult:lpm_mult_component|mult_k3n:auto_generated|le10a" ... Thanks,
VT
--- Quote Start ---
VT
--- Quote End ---
Hi VT,
the warning means that the synthesis engine found logic which could be without changing the design behaviour.
As far as I know, all arithmetic functions supports so-called pipelining. That means that registers stage will be implemented in order to improve the timing. Of course the result will be available some clock cycles later.
I have an example of a divider attached. Maybe it could help you.
Kind regards
GPK
--- Quote Start ---
Hi VT,
Kind regards
GPK
--- Quote End ---
Thanks for the replay.
I know I could improve the timing by adding some pipeline but I want to understand on what those timings depend on. May be I should read more about the lower level of the synthesis.
VT
--- Quote Start ---
VT
--- Quote End ---
I have a small drawing attached to show you how retiming works .
Kind regards
GPK
OK, I have one question now :). Does this mean that if I make a PLL clock multiplier, for example 80MHz and if timings are OK at 20MHz they would be OK at 80MHz as well. What I mean is that the synthesis is adjusted to the clock speed and the connection timings will be proportional to 20MHz?
VT
--- Quote Start ---
VT
--- Quote End ---
as long as you have enough register stages defined it should work. Of course there is a limit, because more pipelining also means higher device utilization. I have a small divider
example attached.
Btw. I mixed up some items:
Pipelining: Means that you or the tool puts some additional registers stage in your design.
Your latency changed, the result is some clocks cycles later available.
Retiming: That is an additional feature to speed up your design. With this feature enabled, the synthesis tool tries to move register through your logic in order to improve the clock speed. The latency did not not change. Hopefully your not to confused now. Sorry.
Kind regards
GPK
