21602 Discussions
Cyclone V ASx4 configuration
I've got a Terasic Cyclone V GX development board. I removed the EPCQ256 configuration device and am testing another alternative (Micron MT25QL256ABA). I created a simple project with LEDS and "generic_quad_spi_controlelr2" and am using JTAG indirect programming to program the device (jic file).
Quartus (17.1) will program the device without error. When I created the jic in "Active serial" mode it is able to boot but in "Active Serial x4" it isn't.
Any thoughts?
Although you are using the Quartus Prime software version 17.1, Can you check once by setting the non-volatile configuration register from the following link for ASx4?
https://www.altera.com/support/support-resources/knowledge-base/component/2018/how-do-i-enable-micron-s-mt25q-support-for-eol-of-epcq---256mb--.html?cq_ck=1522223941654
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Best Regards
Vikas Jathar
Intel Customer Support – Engineering
(Under Contract to Intel)
