hi,
I am working with Cyclone V to receive high rate data from ADC,the clock from ADC is 500MHz, but the LVDS_rx input clock(f hsclkin on datasheet)can only be 437.5MHz.and then, When i generate LVDS_rx IP, the input clk can be configured to 500MHz. i want to know which is right? Can this device meet my requirements? ThanksLink Copied
In this case, you have to refer to the datasheet "High-Speed I/O Specifications" for your Cyclone V speed grade. Maximum input data rate with -C6 is 840 MHz, respectively 420 MHz clock.
--- Quote Start --- In this case, you have to refer to the datasheet "High-Speed I/O Specifications" for your Cyclone V speed grade. Maximum input data rate with -C6 is 840 MHz, respectively 420 MHz clock. --- Quote End --- Thanks for your reply. does this means that Cyclone V only can receive data in DDR mode to reach high data bandwidth as 840MHz?
Yes. Which data rate do you try to achieve 1000 MHz DDR or 500 MHz SDR?
--- Quote Start --- Yes. Which data rate do you try to achieve 1000 MHz DDR or 500 MHz SDR? --- Quote End --- Thanks. I need to receive data 500Mbps, so now the clock coming into Cyclone V must be 250MHz. In addition, can cyclone V receive these data correctly without DPA? Looking forward your advice.
--- Quote Start --- can cyclone V receive these data correctly without DPA? --- Quote End --- Probably yes. What's the ADC type?
--- Quote Start --- Probably yes. What's the ADC type? --- Quote End --- I am planning to use ADC08D1020 and to receive 32bit data lines use an lvds_rx megafuction with the following parameters: input clock:250MHz; data rate:500Mbps; The Cyclone V devices don't have DPA. Thanks.
500 MHz data rate should allow sufficient sample window to operate the receiver with fixed phase relative to DCLK.
Thanks for your advice. I will have a try.
Hello I am doing a similar design but with four ADCs and in a Cyclone 3.
However I am confused about the LVDS clock signal input: are all the input clock IO pins dedicated LVDS? I do not want to have problems about clock mismatches so I need to confirm the IO input clock pin is LVDS compatible, no emulated? I know that for transmitters the question is different but for receivers I didn't find any information. Thanks in advance. Regards
